Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
simple cone shape
5 REPLIES 5
boelle
557 Views, 5 Replies
simple cone shape
boelle
Hi
i have a plate for dust shoe i need to mill, i tried a few of the 3d option but i cant get to where it will make a toolpath the follows the surface
any pointers in what operation that can do the trick? the slot and 3 holes i used ramp and pocket
simple cone shape
Hi
Labels (1)
5 REPLIES 5
boelle
in reply to: boelle
boelle
flow was the only one where i could pick the surface but did not work
f3d file attached
f3d file attached
in reply to: boelle
Pick your favorite 😁
boelle
boelle
i tried them all but i think it failed becaused i had the wrong mill bit in place
i used the flat end mill and i think you use a ball nose one
will check and report back
boelle
in reply to: boelle
boelle
i compared and eyeballed and the only difference i can see is that you use and ball mill which make sense
am i correct?
am i correct?
in reply to: boelle
I missed Contour, .... apologies ....🙄, and the key to solution is in the setup, I selected specific body and I prefer to define Z and X axis orientation, always works, in most cases X is longer than Y on parts done on mill.
When doing slopes, only ball or bull nose end mills are correct type, flat end mill leaves stairs no matter how small the step over.
