Fusion Manufacture
Siemans 840c lathe post help.
6 REPLIES 6
cody
276 Views, 6 Replies
cody
I am having trouble with a post for my lathe. Everything works as far as non cycle toolpaths, but it will not
post when I put any drill cycle in the program. I've attached the .cps and f3d file for someone to look at.
If you post any of the toolpaths except the drill it will work and the code is good. I have ran this machine on
some parts for a while now that did not require any cycle toolpaths, so I never bothered with it, but now I
am using it for one off stuff and need to figure it out. I'm not opposed to longhand code and ditch the cycles. I would
prefer longhand because its a weird control and there just isn't much support out there. Thanks for any help.
Cody C
Cody C
Labels (1)
6 REPLIES 6
seth.madore
in reply to: cody
seth.madore
Huh. I was going to jump in and at least take a look at it, but Fusion is crashing when opening that file 😞
Seth Madore
Seth Madore
cody
in reply to: seth.madore
cody
Seth,
  I had that issue yesterday. I eliminated the last path and reattached. I think maybe it is that causing crash.
Cody C
Seth,
Cody C
seth.madore
in reply to: cody
seth.madore
Turns out it's the In Process Stock caching that's causing the crash. Opened succesfuly, let's see if I can make heads or tails of what's going on. Likely not, I'm not a post guy (at all)
Seth Madore
Seth Madore
seth.madore
in reply to: cody
seth.madore
Seth Madore
Seth Madore
cody
cody
Seth,
  Yes. I will look at and compare. I will also test on the machine and report back for you guy's. I've modified posts for several machines but this thing is weird. I appreciate the help. Please attach or send me the 840c post. You may still
have my email in your contacts.
Cody C
Seth,
Cody C
seth.madore
in reply to: cody
seth.madore
Email sent, but you already know that 😄
Seth Madore
Seth Madore
