In the attached file, when trying to select the edge of the largest pocket to contour around, I can only select each individual segment instead of the complete closed loop like the other pockets.
This image was converted from a jpeg to dxf. then brought into fusion, scaled up and extruded out of the material.
This only happens with this one pocket for some reason.
Any help on this would be much appreciated.
Solved by scottmoyse. Go to Solution.
See attached
Scott Moyse
RevOps Strategy Manager at Toolpath. New Zealand based.
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
Hi @Anonymous
If you select a line from the large contour, then double click the line you just selected, it will open up the countour slection dialogue box which should enable you to select the full contour. I've attached a link which shows how you do this. You can skip to 5.30 minutes in and it shows you what i'm explaining here.
Mat
Hi @Anonymous
Apologies, forgot to add the link to the video on my previous reply. Here it is: https://www.youtube.com/watch?v=EZCRFtiYIGU
Mat
You're welcome
Scott Moyse
