Announcements
select a single face to mill
marc.horner4HYNU
marc.horner4HYNU
This is probably something really simple i am missing, but - how can i select a single face to mill?
I am milling this as a second op and just want to clear out stock on the highlighted taper in 1mm depth of cut passes with a HFM
If i use adaptive clearing 3d then the toolpath goes around the complete part,  if i use 3d contour then the cutter tries to machine both sides of the selected face
LibertyMachine
Selections and constraints. Can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
marc.horner4HYNU
Added to 1st post
all the operations in setup2 are junk ive been playing with
LibertyMachine
Seth Madore
marc.horner4HYNU
Excellent,  Thanks ever so much for your help
Irisusa-LOM
Observer
Observer
I am having the same problem. In your video, you are able to select the lines. I am not able to. Why and how can I fix that?
Much appreciated.
Irisusa-LOM
Observer
Observer
I was able to figure it out. Thank you
