Round Stock
Latheboy
Round Stock
Latheboy
In the stock setup, is there a way to begin with round material vs square for milling?  By that I mean round stock held in a chuck vertically as an example to machine the top and sides?  I don't see that as an option,but I suspect it is there.
Steve
a.laasW8M6T
like this?
You can also select an axis for the stock center to be located.
another option is to model the stock as a separate component and select is "From solid"
Latheboy
Perfect, Thank you
