how can i reverse the 4th axis moves in the Haas NGC post processor ?
Solved by filipH9JM4. Go to Solution.
https://cam.autodesk.com/hsmposts?p=haas_next_generation
If you are using the latest Haas NGC post you get to see the following in the post properties tab
You can choose reverse to change the direction.
