I've got 2 paths being cut out using a 2D Countour. After the first closed loop has been cut out, the path it takes to the second one goes straight through the stop instead of lifting up and over it. Does anyone know how I can fix this?
Solved by Steinwerks. Go to Solution.
Shorten your Stay Down distance or uncheck the Stay Down box entirely.
