Reset 4th axis output when reaches -360/+360 degrees
- Mute
- Permalink
- Report
I have a customized Mach3 post for a 4th rotary axis (A, although it turn around Y). I made it for a RichAuto controlled Blue Elephant ELE1325-8 machine. I have been experimenting with the Rewind or simply limiting the rotation from the MachineConfiguration. I don't really like to rewind the machine after a long Rotary Strategy, and I've just found out that when in jogging mode the machine goes over -359/+359 to 360 it simply nulls the number and goes on from there.
So, my question is, is there a way to trim the rotary axis output in post, so instead of:
G1 A359
G1 A361 ----> i get simply G1 A1, and the same way in the negative direction (A-361 to A-1)
It turns out if I manage to do this, I would not need a long rewind at the end of the program run and still be able to use Spiral mode in the Rotary strategy. (up until now I only used the circular)
Any help appreciated! 🙂
