--I am reposting this issue as I didn't have an answer--
When using subprograms for multiple work offsets the post generates subprograms for each work offset.
It should generate only one set of subprograms for all work offsets.
Latest Fanuc Generic Post for milling.
Why so many subprograms for same operation in multiple offsets example:
Thanks!
Solved by boopathi.sivakumar. Go to Solution.
Yip that works.
The description was a bit ambiguous, I thought pattern operations was referring to the Pattern folder in the browser tree.
