Fusion Manufacture
Remove Extra Plunge Operations: 2D Pocket Profile
1 REPLY 1
rwaldron3711
128 Views, 1 Reply
New to Fusion CAM... Made a honeycomb pattern for a wood carving (Onefinity Elite), I've got the profile all set up for the proper tool paths, but it keeps adding in multiple plunge/helix entry points that aren't needed. The gap is a 1/4" and using an 1/8" bit so it should be able to make one entry and then follow the profile. How can I remove the extra entry points?
1 REPLY 1
seth.madore
in reply to: rwaldron3711
Without seeing the file, it would be difficult to advise, as it's not clear what you've done or are actually running into. My initial reaction is to say "oh, this is how it should work", but it's not 100% clear what you're running into. Thus, I could be way off base here..
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
Seth Madore
