Announcements
Due to scheduled maintenance, the Autodesk Community will be inaccessible from 10:00PM PDT on Oct 16th for approximately 1 hour. We appreciate your patience during this time.
Fusion Manufacture
Rectangular hole
8 REPLIES 8
Message 1 of 9
leoE4H8W
335 Views, 8 Replies
Rectangular hole
I can's get the bottom hole cut, the pockets are good.Screenshot 2024-06-26 125859.png
8 REPLIES 8
Message 2 of 9
programming2C78B
in reply to: leoE4H8W
We will need...some information. You already had a thread open about this.
Please click "Accept Solution" if what I wrote solved your issue!
Message 3 of 9
leoE4H8W
in reply to: programming2C78B
I still haven't gotten it right, please explane again
Message 4 of 9
leoE4H8W
Here's the file
Message 5 of 9
leoE4H8W
Here;s the file
Message 6 of 9
programming2C78B
You are using 2d adaptive with the wrong geometry selected, and the depth is too shallow to include the pocket itself.
Adaptive is usually done with a much larger DOC as well, usually 2x the tool diameter.
It's also .328 wide and your tool is .313, so all leads and stock adjustments must equal less then .015". Use 2D contour with ramp.
Message 7 of 9
leoE4H8W
The x is the pocket and the blue in the hole i want to cut.Screenshot 2024-06-26 125859.png
Message 8 of 9
programming2C78B
yes, im aware of that. None of that changes what I said.
Message 9 of 9
leoE4H8W
I got it, but this is what I get now.
