Hello everybody
I am facing a problem when ramping a 2D contour.
Each time I set up a cut in several passes, the first ramp corresponds to what I want and what I set, 45°angle but the second ramp is much longer and does not correspond to the angle I set up.
The only way to get what I want is to set Depth Cutting in ramp section to 2500mm, by default it's 32mm
Is this normal?
Depth cutting into ramp section set to 32mm
Depth cutting into ramp section set to 2500mm (what I want)
Check to see what your Max Ramp Stepdown is (on the Linking tab). Try increasing that value.
Can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
Thank you for reply
@seth.madore a écrit :Check to see what your Max Ramp Stepdown is (on the Linking tab). Try increasing that value.
I did it.
The first picture correspond to 32mm Ramp Stepdown, second picture correspond to 2500mm Ramp Stepdown.
@seth.madore a écrit :Can you share your file?
Of course.
Oh, I see what you're talking about, I'll get this reported today
It doesn't appear to me that it is. I'll poke at it some more today, but my gut tells me that it should follow a much steeper decent on the second ramp, without having to resort to such a large ramp stepdown value
