Announcements
Problem with undercutting
jscott6SWZG
jscott6SWZG
I am unclear about how to set the top height for an undercut.....by trial and error I discovered that you enter model top with an offset of the tool height.
If so why doesnt the program pick up the flute length from the tool cutter settings????
a.laasW8M6T
Yea its a little confusing
I set the top height as the top of the slot, with a negative offset of the difference between the flute length and the maximum step down value.
so for example if you had a 2mm thick slot cutter with a 1mm stepdown you would put in  an offset of -1mm
or if the max stepdown was 0.5mm then the offset would be -1.5mm
