Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
problem with PP for mach4
5 REPLIES 5
Stuart-H
336 Views, 5 Replies
ok its very difficult to explain but I will try
it does not matter what the am file is the result is the same
ok download the generic PP from the web site
set up a generic a axis machine from your library
point that to the above PP
run a simple 3 axis file and the machine details appear in he post before the tool list
ok that works
but now I have a file that uses the a axis
so as I have done before alter the statement in onopen from false to true
now if I use the machine config in the setup file it fails on onopen with no info why
but if I remove the machine config from the setup and just select the PP from the personal list it works
now the machine description will not show up in the gcode output , but if I remove the onopen changes they show up again
Mac Studio M1Max and MacBook Pro M1
5 REPLIES 5
Stuart-H
in reply to: Stuart-H
I have done a bit more looking into this problem
when using a configured machine in which you have the pp selected but with a new unmolested post from the Fusion post lib it works as expected for 3 axis parts ,ie the machine configuration is outputted in the post ( needed to identify the post)
every thing as above but set up the mach4 post for a axis as per instructions on this site the machine configuration is not outputted in the post
note that is the only change that causes the missing information
engineguy
@Stuart-H
Yes, it has been broken for quite a while now, used to work fine but went south about a dozen updates ago 😞 😞 😞
The "work around" most folks seem to use is the "Passthrough" which allows you to type in the information you want to be output in the code, see below for examples.
Input the information shown below 🙂
and you will get code like this 🙂
No great hardship, only needs doing once and is easy to edit if required 🙂
Hope it is of some use/interest to you, modified your PP to output the Passthrough and it is attached 🙂
Regards
Rob
Stuart-H
in reply to: engineguy
@engineguy
Rob
thanks for the information and your time in modding my post
i hope this next comment does not offend but I am not marking it as a solution as it needs to be picked up by the Fusion360 and put right it dismays me that improvements are made and more things are broken
thank you again
Tomek.G
Hi @Stuart-H,
thank you for bringing this up. When the 4th axis is enabled, the
machineConfiguration = new MachineConfiguration(aAxis); override the machine description.
A workaround is to move the definition of description parameters before 4th axis configuration like so:
  var vendor = machineConfiguration.getVendor();
  var model = machineConfiguration.getModel();
  var description = machineConfiguration.getDescription();
  if (true) {
    var aAxis = createAxis({coordinate:0, table:true, axis:[-1, 0, 0], cyclic:true, preference:1});
Tomek.G
Sr. Technical Consultant
Stuart-H
in reply to: Tomek.G
@Tomek.G
thanks for your time
and of course thank you for the information to resolve it
