Probing for bolt hole alignment
jb4020
jb4020
I have some castings with existing bolt hole patterns and would like to use probing and G68 to align them.  The machine is a Haas vf 3 with classic control.  How would I go about stetting this up in Fusion?  The center of the part is used for the wcs and I would like to pick up 1 bore on the bhp and adjust the angle from there.  Any help is appreciated.
seth.madore
To do this automatically in Fusion, I'd suggest doing some reading on what's called "Part Alignment"
The other option is to do a quick hand-code of the Renishaw P9834 probing cycle
Seth Madore
jb4020
Seth,
Thanks for the quick response.  This is is for a customer and they currently do this manually at the machine on a significant amount of parts and would like to start transferring some of the programming to fusion.  Is there a way to use the 9834 cycle through fusion?
seth.madore
Directly? No.
But, you could make a Manual NC "Pass Through" program. Downside, if you have a family of parts to make, you're stuck "finger-cam-ing" it each time
Seth Madore
jb4020
The manual NC worked as an acceptable solution.  Much thanks!
