Need help with creating a toolpath for inclined/angled slot
simspacetn
simspacetn
I am trying to create a toolpath for an angled slot as shown in the image below.
I'm not having much luck with a 2D trace and I'm hoping someone can tell me the correct way to do this.
If it helps, here's a link to my shared design: https://a360.co/4213uX6
Thanks!
seth.madore
Trace drives it's toolpath off the center of the tip. As you've discovered, it's going to gouge the surface.
There are some other toolpaths to try, but before I provide more detail, I'm wondering about the goal. Is this a practice block that you're just playing around with for the sake of CAM practice, or is this something physical you need to make?
Seth Madore
seth.madore
Options:
Smaller tool and Parallel
.250" tool and Project (it might not work, due to tool being same size as slot)
Flow/Blend with a ball endmill
Other option(s); tip the part at the angle needed
EDM sinker if square corners are needed throughout
Seth Madore
simspacetn
It is a practice block that is for CAM practice and to make my first cuts on my first-ever VMC. I want to run various ops and tool changes on my new-to-me VMC.
simspacetn
I will give those ideas a try later today.
I'm not sure what EDM sinker is, but I will search for it.
