Recently our school purchased an Axiom Auto Pro 8, when it was purchased we were advised to use AutoDesk Fusion 360 as our design software, as we can use a student version for free since the school budget is extremely tight. For about a month now checking forums and trying different ideas we cannot get the CNC to replicate what we designed on the program. In the manual it reads that the RichAuto 11 controller will read standard GCode, we have tried Grbl/grbl, and RS-274D/rs274d, neither one will produce a completed project without some kind of issue. Below I attached our latest try. We are also struggling with time, the program forecasts about 10 minutes, and the actual project takes almost 2 hours. I am definitely a novice so there can be other problems within the program. I am hoping to find an answer in why we are having these dependencies between what Fusion is showing and what is actually getting done, and is there a better generic G - Code to use? Is there a different program we should use?
Your help is greatly appreciated
Thank you
Solved by fonsecr. Go to Solution.
Hi Rene
I am expecting delivery of my 1st router soon, which has a RichAuto a11 controller.. I have been reading the discussions about Posts for RichAuto a11 controllers for use with Fusion 360. If I understood correctly, you were working on such a Post and that at that time it was in Beta. Can you give me any updates and is your Post up and running successfully? If so where can I get it. There does not seem to be a Post for RichAuto listed in the Fusion generic Posts.
If you did not continue with that work, is there another Post that you can recommend please, or is there someone else that you would recommend that I ask?
Many thanks,
Simon
Hi Luke,
I seem to have been round in circles looking for a solution. It is great that you report a positive outcome.
I would be very happy if you are able to follow this through.
Thank you
Simon
Hi Mike
Thank you, but, there does not seem to be a Post or a reference to a Post attached to your reply
Simon
I'm working with a Baleigh PT-22 plasma table that also uses a Richauto A11 controller . I grabbed the Fusion 360 post-processor (a big thanks to all who contributed!) but when I go to post my work, Fusion tells me "Waterjet, laser, and plasma cutting toolpath is not supported by the post configuration". Since you've already got a milling operation supported, would it be much work to add support for plasma?
Actually, I'm embarrassed to say it, but I was so busy looking for "RichAuto" post-processors that I totally glossed over the fact that Autodesk has provided posts for Baleigh as well. There is literally a "Baileigh Plasma" post-processor already ready to go!
In case anyone's looking for it: https://cam.autodesk.com/posts/post.php?name=baileigh%20plasma
Hello Michael! Hope you are fine.
Have you heard that DSP A11 is not performing G02/G03 correctly? I've tested this commands in my brandnew machine and I noticed that it can do arcs but with wrong dimensions, start and end points.
Please, do you know whwther it can be solved via post processor that can write "wrong" G2/G3 parameters to get the moves right?
Thank you in advance for your comments.
Hi there! I haven't had any issues like this, have you tried the post processor specifically for the A11?
harryeU968P, thanks for clear explaination. I just yesterday fond this way by myself.
But I can't solve one thing - a new setted mill continues working on the old "zero level" after choosing menue item "Tool changed" while current coordinate zero level is cganged correctly.
I have a machine running off RichAuto A11x. Manufacturer told me to use default Mach3 (mm and inch) post processors in F350.
Haven't run into an issue yet.
Hello!
How did you get this tool change menu? I cannot get it from my Richauto A11X. What is the G Code that activates it as it is nowhere in the menus.
With regards, Gregor
