I have a nextwave automation shark cnc machine. I don't see a post processor for it. I am somewhat new with fusion 360 and wonder how to procceed. How do i generate g-code for my cnc machine?? Is it possible? I can create an .stl file bring that into vcarve, but it is not ideal.
Solved by LibertyMachine. Go to Solution.
You need to provide a lot more info about the machine, What program run's it Mach3, linuxcnc some other strange name program, What G and M codes it needs.
Have you asked if they have a post processor for it
And insert between code tags (it's beside the smiley face above) a sample G code that vectric spits out
Thanks for the info...How it works is there is a controller box connected to a PC via a Usb cable. My vcarve post processor produces gcode files with .tap extension. It does not use mach3, I wish it did. There is sofware on the PC that actually drives the machine which nextwave wrote. I have examine g-code and know very little about the code itsself other then what I have guessed. Do you know a good reference or should I just google and search.
I have asked the question to nextwave, don't have a response yet. I assume the post processor for vcarve is different than one to be used with fusion.
Dave Hagen
Ok I just had a look my self, it told me beggar all, It looks like it's useing there version of grbl It's in the post processor drop down.
If you can post a Gcode from Vcarve it can be use to compare, say do a 2inch squire with a profile cut and post that, If your not sure what I mean what post processor are you meant to use with Vcarve.
@daniel_lyall@Anonymous
I made one last year for the Piranha series. After some follow up tweaks, I was told that it worked quite well. Link HERE
EDIT: The better version is on the second page
Thank you
Try the post @LibertyMachine posted
