Solved by Steinwerks. Go to Solution.
Sorry you're having problems.
Could you share your part, and the post you're using? Do you know which aspect of the NC code is wrong?
Jeff
I believe I tagged you in the thread, but this one over here has some more detail: https://forums.autodesk.com/t5/fusion-360-computer-aided/engraving-bug-on-wrapped-tool-path/td-p/820...
I was seeing seemingly random retract moves that left sections of the text blank, but it seems to do the opposite on the machine.
@michaelthompson83 I suggest sending the test file we went over to Jeff via email.
