Post Fail with tool orientation for 4th axis positioning
Hi, I've been using the planetCNC post in the library for 3 axis machining with no problems. I have now added a rotary 4th axis and am trying to run a program that requires 16 different tool orientations, and I get errors. It looks the the post is capable of doing 4 axis, but I assume there are modifications needed and I don't know how to do that. Can you help?
See below for errors:
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.10564
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Tool orientation is not supported.
Error at line: 766
Error in operation: 'Pencil2 (2)'
Failed while processing onSection() for record 3116.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, August 252021 12:14:33 AM
Post processing failed.
daniel_lyall
Around line 256 change this
if (false) { // note: setup your machine here
    var aAxis = createAxis({coordinate:0table:falseaxis:[100], range:[-360360], preference:1});
    var cAxis = createAxis({coordinate:2table:falseaxis:[001], range:[-360360], preference:1});
    machineConfiguration = new MachineConfiguration(aAxiscAxis);
To
if (true) { // note: setup your machine here
    //var cAxis = createAxis({coordinate:2table:falseaxis:[001], range:[-360360], preference:1});
    machineConfiguration = new MachineConfiguration(aAxis, /*cAxis*/);
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
boopathi.sivakumar
Hi @Anonymous
In addition to what @daniel_lyall said make sure the parameters defined in the createAxis is matching as per your machine. You can read the documentation here How to set up a 4/5 axis machine configuration - Autodesk Community- HSM
For a typical 4th axis mounted on the table along X will have a kinematics something like below
    var aAxis = createAxis({coordinate:0, table:true, axis:[1, 0, 0],cyclic:true, range:[0, 360], preference:1});
    //var cAxis = createAxis({coordinate:2, table:false, axis:[0, 0, 1], range:[-360, 360], preference:1});
    machineConfiguration = new MachineConfiguration(aAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(1); // TCP mode
Boopathi Sivakumar
Principal Technology Consultant
Thanks Daniel,
I copied the revised text from your email and pasted it into the post, but there was a syntax error on line 259.
This is line 259 as copied:
     machineConfiguration  =  new   MachineConfiguration ( aAxis , /* cAxis*/ );
I also made the change per the message from Boopathi to change (0) to (1) in this line:
Thanks for your help.
daniel_lyall
That's my fault the /* is in the wrong places
It should be like this
machineConfiguration  =  new   MachineConfiguration ( aAxis /*,  cAxis*/ );
Not this
Example attached
Daniel Lyall
The Big Boss
Mach3 User
