07:40 PM
- Mute
- Permalink
- Report
Hi, I've been using the planetCNC post in the library for 3 axis machining with no problems. I have now added a rotary 4th axis and am trying to run a program that requires 16 different tool orientations, and I get errors. It looks the the post is capable of doing 4 axis, but I assume there are modifications needed and I don't know how to do that. Can you help?
See below for errors:
Legal: Copyright (C) 2012-2020 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.10564
Warning: Work offset has not been specified. Using G54 as WCS.
Error: Tool orientation is not supported.
Error at line: 766
Error in operation: 'Pencil2 (2)'
Failed while processing onSection() for record 3116.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Wednesday, August 25, 2021 12:14:33 AM
Post processing failed.
