Hi everyone,
I have some problems with fusion making routing plans. As you can see, it does not plan everything I select. I consider this to be really strange. I also tried this using the 2D Adaptive Clearing, but that gave the same result. Do any of you know what is going on and how to fix it?
Thanks in advance!
Philca
Solved by seth.madore. Go to Solution.
Hmm. Can you share your file?
File > Export > Save to local folder. Return to thread and attach the .f3d file in your reply
2D Pocket or Adaptive is just going to fall on it's face with as much geometry as what you have going on. I'd suggest using 3D Pocket or Adaptive to accomplish the same thing with just one toolpath:
@seth.madore wrote:2D Pocket or Adaptive is just going to fall on it's face with as much geometry as what you have going on. I'd suggest using 3D Pocket or Adaptive to accomplish the same thing with just one toolpath:
Okay, thank you very much!
