Please--Need Input on Mill Toolpaths
utekcnc
utekcnc
Attached is a CAM file.  I am wanting to machine the grooves in the vice jaw.  I was going to rough out with a square endmill and then finish with a ballnose.   Could someone please tell me which process I need?  Should I use a 2D contour or a 3D parallel cut?  Thanks!
LibertyMachine
Here you go. I ended up using 3D Adaptive to rough out the slots (although you def. could simply lay out some 2D Contour passes) and finished it with Parallel.
Seth Madore
Owner, Liberty Machine, Inc.
Good. Fast. Cheap. Pick two.
utekcnc
Thanks Seth, is there a speed and feed calculator for the adaptive toolpaths?  I know with Volumill we usually change our feeds upward dramatically.
LibertyMachine
One of the more accurate calculators on the market: http://hsmadvisor.com/  It's a purchased calculator, but a lot of people swear by it.
If you are looking for free, the one from Helical Tool is a solid choice. The couple of downsides to Helical: Checks for internet connectivity every time you use it, and it also relies on the EDP # of the tool. You can get that from the catalog and just find a comparable tool of your preference .
Seth Madore
