Fusion Manufacture
plasma cutting is offset
1 REPLY 1
jordanbobsmith
266 Views, 1 Reply
i'm having another problem which i can't seem to figure out. finally got a g code in post process that works for my plasma cutter. (hypotherm jet).
my problem is though each piece seems to start offset. what i mean by this is lets say i have two squares with a 20 mm gap in-between. for some reason my the gap isn't correct. everything else is right. i have linked a photo and the f3d file swell as a link to the controllers unit i use.
the controllers unit is a chines model that runs the hypotherm plasma cutter.
the photo i have attached has two arrow and you'll see the gaps are not the same
controller ->   https://www.alibaba.com/product-detail/CNC-controller-cnc-control-system-for_1600063547878.html?spm=...
1 REPLY 1
