I am trying to get all the parts of this part to cut. I've tried selecting the face contour and I've tried selecting each chain. They all appear to be selected, but when I run the simulation not everything is included. It's not necessarily the same parts that are left out each time. The ones I've indicated here are more likely to be omitted, but not always. Any suggestions will be appreciated. BTW: The part is ~13 x ~8.
There is probably a discrepancy between the tool diameter and the profile width of the cut-outs.
i.e. the tool diameter is too large in some places.
günther
Would you be able to share your Fusion file here?
File > Export > Save to local folder, return to thread and attach the .f3d/.f3z file in your reply.
I'm not sure this is the exact file I inquired about because I tried so many times.
I've read about "fine cut" consumables for detailed work. I don't know anything about them and don't see how F360 would differentiate if you have simple entered your plasma cutter. In my case I am using a Langmuir Crossfire with a Primeweld machine torch.
I created a new "tool" with the nozzle size of 0.031 rather than the 0.055 that was recommended when I first got the Crossfire. All the parts were cut in the simulation so I ordered some of the smaller nozzles from Primeweld. I'm out of town right now, but will try a cut when I get home.
