Solved by fonsecr. Go to Solution.
There is no tangential extension feature available. However, you can either extend the faces to be machined or maybe use big lead radii to get some similar effect - you might need to choose "No contact" so you force the leads for each cut.
Note that it is gennerally unsafe to only select a few faces for machining as the remaining faces wont be considered for the toolpath calculation. So you have to verify extra carefully that you didnt make a mistake.
The default behavior for the 3D strategies is to stay in contact with the part as much as possible when moving between cuts. You can turn off this behavior by selecting No contact as the Transition Type.
I need to check why the contextual help is not showing up with most details. This is not intended.
