Fusion Manufacture
OSAI UAO problem
2 REPLIES 2
craig.mckee
767 Views, 2 Replies
OSAI UAO problem
Hi
Hope someone can help. we have just installed a MaxiCAM CNC router with an OSAI controller. We are having a problem with the UAO line within the Fusion G code output.
Fusion would appear to select UAO, 0 as a default. Unfortunately the controller does not have a 0 origin option it runs from 1~9.
Does anyone know if it is possible to change the default origin selection within fusion to a different number?
Thanks in advance
Tags (1)
2 REPLIES 2
vid.kok
in reply to: craig.mckee
You will have to modify the postprocessor. Here is the video on how to do that:
craig.mckee
in reply to: vid.kok
Fantastic, thank you so much for your help, we are just trying out the solution now
