There is a discrepancy between the simulation coordinates and the output from the Okuma post, specifically in the Y direction. When I run the program on the machine, it attempts to drill in the wrong location. The Y coordinate from the simulation appears to be correct for the drilling location. The difference between the two Y coordinates seems to be consistent with where the drill should actually be positioned. I'm using the machine configuration that was already in fusion for this machine.
Solved by TrollTuner2. Go to Solution.
Try Using Fixture Offset Function (Call O088) for the 3+2 stuff. Its under the multi-axis tab in the post properties. Thats what I use on my 460-5ax
(Slot Rough)
M09
M01
N4 T338 M06
S15000 M03
G17 G90 G94
G15 H03
G00 A-90. C145.488
M08
G131 F150 J1. E0.0004
CALL OO88 PX=0. PY=0. PZ=0. PC=145.488 PA=-90. PH=3. PP=51.
G15 H51
G00 X3.9127 Y-3.3008
CALL OO88 PX=0. PY=0. PZ=0. PC=0. PA=0. PH=3. PP=51.
G15 H51
It uses H51 offset as a scratchpad. offset H3 drives it in my setup.
Great. Yell if you need anything.
Don't know much, but I get the Okuma to make the parts right most of the time.
