- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Currently using a modified Okuma post processer, to account for the the offset between the B axis & C axis on our Nikken rotatory table. Said offset was verified by @bob.schultz (thank you Bob) & is manually entered in the post processer per this forum post.
This works great, until we machine past 90°, see sample below showing X value @ 75°, 90° & 105°. Our Nikken's B axis ranges from 0 to 105°
In fusion, I drew a line @ B90° & selected it for the same 2D Contour operation @ all 3 B moves above w/ Compensation Type: Off & Lead In/Out disabled. This put the spindle right on center w. the line drawn.
The X value for the 105° should be identical to the X value @ 75°, both being 15° away from 90°, however, something in the post processer is not applying a negative value once the rotation is past 90°
A full list of post modifications can be found here for reference
