New to Manufacture: First Move z:0 and scrapes along part to first position?
madmackz
madmackz
Fusion360 Personal License
Manufacturing
Cnc Machining / GRBL
Z Height start position Issue
As In the title, I setup my home location by simply zero everything to where I desire. Upon hitting start, Tool Drops rapidly to z:0 and drags along x axis to first position, Only then it lifts to retract height and proceeds to z:-0.63mm (as it should) and proceeds. Why is this occuring? Why wouldnt the move to first position respect/consider my safe retract heights etc?
I am using GRBL and have chosen such in post prcoessor, G28 enabled
jscott6SWZG
I use grbl as well.  Not sure what is going on with your set ups.
I set xy then z, i raise the tool to clearance height.  Then hit return to work piece zero.
i check that this is where i expect the work piece zero to be and also the height of the tool.
i hit send and watch the tool move to  the first tool path and plunge to feed height.
jscott6SWZG
programming2C78B
Use this post. It retracts as the first command.
Please click "Accept Solution" if what I wrote solved your issue!
