I'm working on a mill/turn project, I have the part programmed except for the clearance pocket on a inside diameter.
What would the procedure be to generate a tool path for the pocket? I'm using a a 2" dia x .250 wide slotting cutter with .060 corner Rad, which is the same as on model. Any help greatly appreciated!
Solved by programming2C78B. Go to Solution.
simply a 2D contour. Select the arc. Lead in enough to start outside.
Bottom height is your bottom. Top height will depend if you are using depth passes or not. I usually just do the math of distance + tool width = bottom height.
