Hey there. I'm new enough to this side that I might not be using the right terms, so please bear with me. I'm working on a project to mill a tile design (into wood). I'm coming from some experience with FDM, and learning that I may need to alter things when thinking about subtracting material using bits. I've been able to create a CAM setup and playing around with a first pass which looks like this:
I see that it's skipping a lot, so I added a second pass with a smaller tool. It's better, but as you see below where I've circled in red, there's a lot which is not being cut. So that's my question -- how do I go about the process of resolving this so that it will cut all of the material I need it to? I've played with a bunch of settings and just seem to be going in circles at this point so could use some general troubleshooting guidance. Thanks!
