Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
NEED HELP WITH POST PROCESSOR SIEMENS MILL/TURN
2 REPLIES 2
romulus_lancranjan
192 Views, 2 Replies
Hello, I need a little help, I want to make a hole with the drill on the lathe in tha middle (x=0), of the part and the processor changes my rotation from the chuck to the drill as if I had a mill
here I think it is wrong, do not check the second condition, the lathe is a DMG MORI T1
thank you for your time
switch (currentSection.spindle) {
case SPINDLE_PRIMARY: // main spindle
if (machineState.isTurningOperation || machineState.axialCenterDrilling) { // turning main spindle
gSpindleModeModal.reset();
writeBlock(
spindleMode,
"S" + getSpindleCode(currentSection) + "=" + sOutput.format(_spindleSpeed),
(tool.clockwise ? getCode("START_MAIN_SPINDLE_CW") : getCode("START_MAIN_SPINDLE_CCW"))
} else { // milling main spindle
writeBlock(
spindleMode,
tool.clockwise ? getCode("START_LIVE_TOOL_CW") : getCode("START_LIVE_TOOL_CCW")
2 REPLIES 2
In your tool library, do you have the tool defined as a "live tool"?
Is the hole perfectly on center? If it's the slightest bit off, it will force out a live tool command.
Seth Madore
YES :))))
sorry for your time i'm new in Fusion  🙂 thank you
