NC editor does not open after posting code
KerryHarrison
KerryHarrison
The NC editor no longer opens after I post code. Open NC file in editor is checked in the post process window.
Any suggestions on how I could correct this?
Kerry Harrison
XanderLuciano
Strange, have you tried opening brackets up before posting your program? Does it work then?
HughesTooling
In preferences you can select a different editor to see if that works, for example if you're using windows try Notepad.exe. A nicer option if you are using a PC is nc-corrector, it is backplotter and editor.
Mark
Mark Hughes
Owner, Hughes Tooling
KerryHarrison
All fixed! Thanks for your help and the link to that editor. It's a lot better then the fusion editor.
Kerry
