- Mute
- Permalink
- Report
Hi. I am having major issues with a 4th Axis project in Fusion. I am trying to do a rotary pocket rough pass.
The tool paths seem erratic often crashing through stock and making deep cuts that break the tool.
Despite defining where the headstock is, I get links going directly into it. Fusion will not let me trim any paths.
I often get horizontal ramps in to a cut with the tool taking an excessive run up and often crashing through stock.
When I try to set machining boundaries, for instance with silhouette, Fusion complains about "invalid geometry - closed machining boundary required".
Fusion repeatedly crashes on simulations
During simulations, Fusion reports tool crashes that aren't there.
So far I have tried:
Setting high feed rate mode to "always use high feed" (I don't think this is "dog leg syndrome")
Turning off smoothing
Trying unsuccessfully to set machining boundaries
Playing with clearance settings / ramp lengths
Nothing seems to help. My CNC seems fine and have tested it on a known good 4th axis file and everything is working as it should. I've spent a small fortune on flex tokens, bits and stock trying to make this work. Any help appreciated.
