You have just missed one setting under the Passes Tab to make it work. You really need to turn off your model sketches in the Manufacturing Environment since you are not using them. Model is attached, run the Simulation.
By the way, I want to bring something to your attention. When responding to a post from someone, do not use the "Post Reply" icon as this will address your post to yourself. Instead use the "Reply" icon on the post you are responding to address your post to that person. Look back at the messages in this post and you will see what I mean.
John Hackney, Retired
