Hi all,
I regularly export nests to DXF (within manufacturing extension) to create a visual layout of parts and minimum stock size for the CNC operator to select/optimism stock.
However, if I modify the manufacturing model to tweak the nest the changes aren't reflected in the export. I have to modify them in AutoCAD to show the correct (modified) nest. Is there a way to show these changes in the export or am I stuck with the original nest?
TIA
