Announcements
Miter Fold tool path help please!
OliverDownie
OliverDownie
Hello all (or anyone)!
I'm hoping for some help here. I've attached a file of two corner stools that I'm trying to cut.
Thee issue is with the 45deg bevel cuts. I'm using a big v bit, but it's not big enough to cut straight down on a contour, so I've tried using:
3D Contour - this machines the top, or it won't go down all the way if I use .25" step-downs and takes forever to generate.
3D Ramp - seems to work better, but breaks the faces up into weird unntinuous parts. Then, as it changes faces to cut, it seems to ramp down forever, so long that I had to stop the program, but I could see the G code flying through.
I do a fair amount of miters, and unless the bit is big enough, I guess I'm lost.
Much appreciated in advance.
Replies (7)
OliverDownie
This might help show what I' talking about.
Attached image is of the 3d Ramp toolpath - this one essentially stops half way through.
OliverDownie
Worked out how to add a pic, finally.Miter fold toolpath?Miter fold toolpath?
karina.harper
Autodesk Support
Autodesk Support
Hi @OliverDownie
I made a version that seems to work with a 3D contour and a trace operation to finish it.
https://a360.co/305GBoE
What do you think? Does this have the error you're talking about?
Cheers,
Karina
Karina Harper
Software QA Engineer, Fusion 360
Fusion 360 Webinars | Contact Support | EDU Support | Support Board Best Practices
karina.harper
Autodesk Support
Autodesk Support
Hi @OliverDownie
Is this still an issue?
Cheers,
Karina
Karina Harper
OliverDownie
Hi Karina,
Thank you.
It says that I don't have access to this page for some reason.
karina.harper
Autodesk Support
Autodesk Support
Hi @OliverDownie
Hm, that's weird. Try this link: https://a360.co/30aUCRM
Cheers,
Karina
Karina Harper
OliverDownie
You're awesome, thank you!
Seems like it will work.
I understand now that you need to add the trace to finish up for whatever reason (seems unnecessary!)
I does look like it slows down on one part - which was happening before, but I'll run it and see what happens.
I came up with my own work around using an adaptive clearing going down 1/2" x 2" perimeter to clear out for the v bit, then using a 2D contour. Other programs that I use can do this all in one tool path.
That's Fusion - so good and frustrating at the same time.
Cheers
Oliver
