Fusion Manufacture
Milling into a curved surface
2 REPLIES 2
bruce2EAAY
413 Views, 2 Replies
Has anyone any idea what strategy to use if i want to mill into a curved surface ?
I have a 3 axis machine
The only strategy that works is 3d parallel as it has variable Z, but he result is not correct
2 REPLIES 2
bruce2EAAY
in reply to: bruce2EAAY
I also tried the following, by defining my own axis during setup and making a simple pocket.
For some or other reason i cannot convince Fusion to mill this pocket with any of the 3d strategies ?
Maybe i am just being dumb, but i am stuck here.
Tags (1)
mathew.hutton
Hi @bruce2EAAY
Are you able to attach your project so i can have a look. If it's the pocket you are looking to machine, you may be able to use a 2D strategy.
Mat
Mathew Hutton
Manufacturing Specialist
Technology Administrators
