Milling 11* angle with live tooling on doosan 2600y lathe
LukeR054
LukeR054
I'm trying to mill an 11 degree angle with a 6mm endmill but unsure which strategy I should use, whether it be a 2D or 3D. So far I've tried out Face, Parallel and Scallop but no luck. Attached a mini sketch and a model. Preffererably would like the endmill to cut on its side rather than its cutting edge at the end just to speed up the process
a.laasW8M6T
Hi
There's nothing attached to your post, can you try again?
Andrew Laas
Senior Machinist, Scott Automation
