Tapered Ballnose Diameter
I've noticed an odd discrepancy when programming with tapered ballnose tools in the CAM workspace.
Although the tool parameters are set correctly in my tool library, once I actually load the tool into a setup the diameter changes. In the screenshot I've attached, my 1.5mm R0.75mm tool shows up as 1.41443mm R0.75mm. Yet when I go to edit the tool parameters, the correct values are visible again.
Is this diameter change going to affect the way my toolpaths are generated, or is this simply a case of a bug causing Fusion to show the wrong number?
From what I can tell, this diameter change only seems to occur with tapered tools that are configured as "ball." If I change the tool to a bullnose with the same radius, I no longer see this issue (but if I do that, my taper angle is no longer correct).
