Fusion Manufacture
Manufacturing Toolpath Help
12 REPLIES 12
Message 1 of 13
manlieststuff
278 Views, 12 Replies
I'm newish to understanding CAM software & I cannot figure out how to change this toolpath. For some reason, the drill bit keeps circling up & down; causing a longer production time &, quite frankly, a lot of unnecessary movements. How can I tell the tool to not reset each time? See reference video below. Thanks in advance!!
Labels (2)
12 REPLIES 12
Message 2 of 13
From your video, it seems you are using an End Mill to create your hole although you mention a drill bit.  With the Helical Feed it cannot be a drill bit.  Anyway, attached in a model with a 1/4" End Mill creating a 1/2" hole.  I hope it helps.
John Hackney, Retired
Message 3 of 13
My error. Yes, the tool selected/being used is an end mill 1/4".  And I can't seem to open the file you attached.
Message 4 of 13
etfrench
in reply to: manlieststuff
A bore toolpath would be more appropriate:
ETFrench
Message 5 of 13
manlieststuff
in reply to: etfrench
Would this mean I would need a bore tool path just for the holes? I was hoping to have one tool path for the entire piece, but it's only the holes that are giving me this unnecessary plunge/retract movements.
Message 6 of 13
I do not have any issues with it but I have attached it again.
Message 7 of 13
etfrench
Yes, it requires multiple toolpaths.  Simply create a folder and put all of the toolpaths which use the same tool into it. Post the folder.
ETFrench
Message 8 of 13
Okay, here's what I'm working with so far. I'm still having issues with the tool retracting/plunging unnecessarily. I attached the file. Thanks all!
Message 9 of 13
Wait, it doesn't look like the free version saves the CAM settings. Once I get the drive to redo the toolpaths for the millionth time, I will post snapshots here. Sorry
Message 10 of 13
I do not think you are correct on this assumption.  I added toolpaths to your model using my Fusion Personal License and do not see any issues.  I am not sharing it since I did them very quick and did not check any settings so I do not want to give you a bad file.
Message 11 of 13
etfrench
No toolpaths in the file.  Here's the bore and pocket toolpaths:
ETFrench
Message 12 of 13
Thanks everyone. I was able to figure out a toolpath to do the trick. I appreciate all of your help.
Message 13 of 13
etfrench
Which toolpaths?
ETFrench
