Hi all
I am looking for a post processor for our MAKA MM7t 5 AXIS CNC Machine, does anyone know of one, or can somebody help
Best Regards
Stephen
Solved by seth.madore. Go to Solution.
Do you have any sample programs you can share that might give us a hint what sort of g-code you're looking for?
It must have a .nc, .tap or .txt extension, so you may have to rename the extension to share it.
Hi Seth
Many Thanks for your quick response
Attached are 2 files
P5548 is a file from previous owners of the machine and as you will see at the start of the code, they were running 3 Maka machines.
P1982 is a file we had written for us and adapted to work.
Best Regards
Stephen
Hmm. It looks like the modifications needed to get a post operational will likely be more than just a few quick edits. I'd encourage you to work with a reseller who specializes in post processor editing, you can find a list HERE
Many Thanks for your Time Seth
I have contacted someone from the list and awaiting a call.
Best Regards
Stephen
Also looking for post Siemens 840D head head for Maka mk7. If anyone have one let me know! Ymitev96@gmail.com
