- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a problem creating straight machining paths in Fusion. I use the Steep and Shallow method for 5-axis lead and lean machining. The machining direction in the Y-axis is fixed, so it would be desirable that the software could create straight lines in this direction, but this is not the case.
1. We can already see visually that in some cases, in the curved area, the line in the middle of the workpiece is going left and right, but ok, this is not a big deal yet (Picture 1).
2. The problem arises when I export the machining path/points that Fusion generated and plot the results. Here, we can clearly see the path deviation since it creates a Zig-zag pattern in the middle of the workpiece (Picture 2).
I calculate the optimal direction and minimal speed in this Y-direction. I now have to generate a machining path in this direction and verify the minimal speed, but this speed is always incorrect because it is caught in that Zig-zag Fusion pattern.
Why is Fusion doing that and how to eliminate it?
