Fusion Manufacture
Talk shop with the Fusion (formerly Fusion 360) Manufacture Community. Share tool strategies, tips, get advice and solve problems together with the best minds in the industry.
machining an inclined slot
6 REPLIES 6
483 Views, 6 Replies
I have a Queen Bee Pro ( a 3 axis CNC machine). I have this model in Fusion 360. But I'm not able to generate a toolpath acuratly. I have tried Adaptative clearing both 2d and 3d but it not working.
Could anyone help me out?
Tags (2)
6 REPLIES 6
seth.madore
How are you holding the part, is it flat against the table, or are you presenting the slot normal to the Z axis?
Seth Madore
seth.madore
That's only going to get you so far, as you won't be able to do anything close to the undercut area. In Fusion, look down on the part from the direction of the Z axis. That's all you'll be able to machine, unless you present the slot itself normal to the Z axis, and not the entire part.
3D Adaptive, however, should be able to rough out what it can. Can you share your file?
Seth Madore
Here is the file https://a360.co/2VNK2jG
So I have to incline the piece at the desirable angle on the table?
seth.madore
Seth Madore
OK. Thank you for the video, I have learn a lot through it
You were very helpful :heart_suit:
