Fusion Manufacture
M8 Coolant Issue
7 REPLIES 7
Message 1 of 8
383 Views, 7 Replies
M8 Coolant Issue
I'm having an issue with a posted program not turning on the coolant with the M8 command. I'm using Fusion 360 and a Siemens 840D Controller. the post has the M8 command but will not turn the coolant on automatically. I can turn it on manually and it will shut off for the automatic tool change but will not restart unless I turn it back on manually. The post I'm using is - Siemens SINUMERIK 840D / Siemens 840d. Any help would be greatly appreciated.
7 REPLIES 7
Message 2 of 8
johnswetz1982
Are the tools in your tool library set to use flood coolant? Or is the program posting a M8 and the control not honoring it?
Message 3 of 8
daniel_lyall
As a test put M8 into the MDI, by default the M8 is in the post if this fails, try M7.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Message 4 of 8
in reply to: johnswetz1982
Yes, it is loaded into the post but does not turn the coolant on. All the tools are set up for flood coolant in the setup.
Message 5 of 8
in reply to: daniel_lyall
Using M8 in the MDI the coolant works just fine. I tried using M7 in it's place in the program and that did not work either.
Message 6 of 8
johnswetz1982
if there are set up in the tool definitions, make sure you have the latest version of the post. There is a comment on the change log on 4/1/2019 that there was an edit "Fixed potential coolant output issue. (#87)". The first section of the post to check would be,        840D_Coolant.jpg
Message 7 of 8
The post I'm using is just as the screen shot you posted, the date however of the revision is 09-06-2018. Not sure how to download/upload a new post revision but I'll take a look at it.
Message 8 of 8
// samples:
// throughTool: {on: 88, off: 89}
// throughTool: {on: [8, 88], off: [9, 89]}
var coolants = {
flood: {on: 8},
mist: {},
throughTool: {},
air: {},
airThroughTool: {},
suction: {},
floodMist: {},
floodThroughTool: {},
off: 9
