Live tooling lathe with Y axis
I have a Lathe with Live tooling and a Y axis.  I am trying to mill a pocket or circle in the side of the part in the Y-Z plane. I am using Fusion 360. How do  I get the tool to orientate correctly so the tool is held in the X axis direction and milling is done in the Y and Z axis direction ?
Best Regards
David
seth.madore
Tool Orientation is what you are going to need to turn on. It's on the Geometry tab of that toolpath. Select the cylinder as your Z axis to align the tool properly
Seth Madore
To orient tool in radial direction, Z axis (blue arrow) needs to point in direction tool is coming from, you can pick face as I did in sample below or you can pick sketch line.
If blue arrow points in opposite direction, check "flip Z axis" box to correct it.
If you pick sketch line, that line needs to be perpendicular to face of feature you intend to cut, in case of drilling side  hole you pick wall of the hole as orienting feature.
If no convenient feature exists for what you need to do, you create sketch line and use it as tool orientation.
@seth.madore , picking cylinder (main body) orients tool in axial direction which is default in mill/turn setup and does not need to be selected for any face milling and drilling / tapping orientations.
seth.madore
Bah! Yeah...that's what I meant 😛
Seth Madore
Thank You, that was want i needed.
Best Regards
David
Jeremiah.Busscher
Hey,
After you pick Z in the tool orientation for your live tool, does it matter which was x and y are pointing? I have
a haas Cl-1 with 2 live tools. Also post processer for cl-1 didnt have live tooling working last I checked. Tools on the turret move x positive to work piece,  but the live tools need to move x negative to  work piece. Any help with that would be great. Do I need to set the live tools with a negative number when x dia measure?
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
