Linuxcnc post process G53/G28 expose U W
alkabal
alkabal
Hi
Using last post pro :
$Revision: 43417 b3f6dbdfcd70762dba17b30aa375adf857a7c460 $
$Date: 2021-09-08 20:16:35 $
I have noticed than uf you use use G53 that seem to be good result is :
N14 G53 G0 X0.
N15 G53 G0 Z0.
And if you use G28 result use U W :
N14 G28 U0.
N15 G28 W0.
Please can you check that ?
Best regards
Replies (8)
alkabal
comparing linuxcnc post pro for milling/turning they have many difference (norelated to missing Y axis)
Imh something can be more logic if you can  synch the most part of the pro from one to other.
Br
alkabal
bump please
I don't understand what is for this U W on a X Z only Linuxcnc lathe machine ?
engineguy
@alkabal
On a Lathe the X can be U and the Z can be W, your LinuxEMC Control should be able to read and deal with either, these are not extra/different axis.
andypugh
In LinuxCNC U and W very much _are_ separate linear axes and the interpreter will throw a fit if the G-code attempts to move them and the system is not configured to include them.
The postprocessor should not be including U and W in the G-code when targeting LinuxCNC.
Curiously, though, I use Fusion and the LinuxCNC lathe post all the time, and don't have spurious axes appearing, so I suspect that config switches somewhere are being set incorrectly.
alkabal
Many thanks for reply
Maybe i'm wrong but i think that linuxcnc does not use G28 U W
https://www.forum.linuxcnc.org/qtpyvcp/42340-probe-basic-is-it-possible-to-embed-a-gladevcp-tab-in-t...
I have do the test as you can see the linuxcnc interpreter fail with U
Br
alkabal
Oh sorry andypugh i do not see your post before send the last redundant message.
The problem appear only using G28 for retract, maybe you use allways G53.
engineguy
@alkabal
If you want to remove the G28 option from your "Properties" list then you can simply "Comment out" that line in the Linux PP as in the image below by putting the two // at the start of that line, it will always then be G53 output.
From what I understand Linux will accept the G28 U W but has to be configured to do so and it is normally not configured that way.
alkabal
Thanks a lot for pointing the most easy solution.
I have mostly do this topic for ask review from the team for confirming this potential wrong usage with Linuxcnc lathe post pro.
Best regards, thanks for support
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
