Hey everyone.
Why am I seeing this high federate before going into the cut? Please see screenshot and attached part.
Solved by akash.kamoolkar. Go to Solution.
@jeph00 Seems like there's a diagonal rapid move that shouldn't be there. I'll make a ticket for this. In the meantime, as a temporary workaround, if you increase the safe distance to maybe 0.2 that will fix the feed rate.
Akash Kamoolkar
