damincin wrote:
Interesting... I hope the original poster doesn't mind me posting this here. When I first tried this, I don't think they had posted their part so I just drew up a rectangular part with an off center hole and tried to do an internal profile. I just looked at it again and can't get it to work at all. And if I try to set the X axis to one of the edges it rotates it about 45 degrees from that edge.
Is it just me?
Dave
@Anonymous I played with your file a bit more and got it working by rotating it in the model work space so the hole is around the Z axis like this.
Why it should make any difference I don't know, the orientation of the model should not matter. I wonder if it's to do with the spun profile as I've not had any problems with parts that aren't around the Z axis before.
Mark
I've attached the file. I made the part into a component then rotated, I had to delete the set up as it would not work after rotating the part,
Mark Hughes
Owner, Hughes Tooling
